Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the two round rubber feet at the hinge-edge of the laptop.
Remove the eleven 4 mm Phillips #00 screws from the back panel.
Using a plastic opening tool pry the back panel off of the laptop.
Remove cable connecting the screen assembly to the the motherboard.
Remove the three 4mm Phillips #00 screws in the hinge to loosen the motherboard fan.
Lift the hinge up.
Remove the three Phillips #00 screws securing the hinge to the IO board.
Remove the Wi-Fi card by pulling it straight out of its connector.
Lift the entire lower assembly up and off of the hinges securing it into place.
7 outras pessoas executaram este guia.
5 comentários
If anyone knows of a good, reliable source to buy a replacement screen assembly let me know, please. I have a 303U with the 1800 screen and I accidentally sat something heavy enough on top of the laptop to crack the screen on the right-third of the screen. I can’t use half of the touch screen and it’s fairly obvious depending on the color/brightness of the content I’m looking at. Would like to be able to replace this and these steps are pretty easy for me to follow so I’m confident I can have a newish looking laptop again if I can find a replacement screen.
Hi ! Did you manage to find one? I’m trying to do the same thing :)
The bottom of the pictured device may feature Phillips #00 screws, but I also have this laptop and the screws around the edge of the bottom panel are Torx T5s on my device.
Same here, asus ux303u screen side hinge is stuffed. But I think it may actually be the plastic screen cover itself where the hinge attaches, not just the hinge.
