Ir para o conteúdo principal
Asus ZenBook UX303U Motherboard Fan Replacement
O que você precisa
  1. Asus ZenBook UX303U Motherboard Fan Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the two round rubber feet at the hinge-edge of the laptop.
  2. Asus ZenBook UX303U Motherboard Fan Replacement: passo 2, imagem 1 %32
    • Remove the eleven 4 mm Phillips #00 screws from the back panel.
  3. Asus ZenBook UX303U Motherboard Fan Replacement: passo 3, imagem 1 %32 Asus ZenBook UX303U Motherboard Fan Replacement: passo 3, imagem 2 %32
    • Using a plastic opening tool pry the back panel off of the laptop.
  4. Asus ZenBook UX303U Motherboard Fan Replacement, Battery: passo 4, imagem 1 %32 Asus ZenBook UX303U Motherboard Fan Replacement, Battery: passo 4, imagem 2 %32
    • Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool.
  5. Asus ZenBook UX303U Motherboard Fan Replacement: passo 5, imagem 1 %32 Asus ZenBook UX303U Motherboard Fan Replacement: passo 5, imagem 2 %32
    • Remove all seven 2 mm Phillips #00 screws from the battery.
  6. Asus ZenBook UX303U Motherboard Fan Replacement: passo 6, imagem 1 %32 Asus ZenBook UX303U Motherboard Fan Replacement: passo 6, imagem 2 %32
    • Pull the speaker connector toward the edge of the laptop to disconnect it from its socket.
  7. Asus ZenBook UX303U Motherboard Fan Replacement: passo 7, imagem 1 %32 Asus ZenBook UX303U Motherboard Fan Replacement: passo 7, imagem 2 %32
    • Lift the battery connector straight up off its socket to disconnect it from the motherboard.
    • Do not pry on the socket itself or you risk damaging the motherboard.
  8. Asus ZenBook UX303U Motherboard Fan Replacement: passo 8, imagem 1 %32 Asus ZenBook UX303U Motherboard Fan Replacement: passo 8, imagem 2 %32
    • Lift the battery and speakers up and pull out to remove.
    • Check underneath the battery for the wire assembly connecting the touchpad to the motherboard. This connection may stick to the underside of the battery. Be careful not to damage it when removing the battery.
  9. Asus ZenBook UX303U Motherboard Fan Replacement: passo 9, imagem 1 %32
    • Remove the speakers from the old battery.
  10. Asus ZenBook UX303U Motherboard Fan Replacement, Motherboard fan: passo 10, imagem 1 %32 Asus ZenBook UX303U Motherboard Fan Replacement, Motherboard fan: passo 10, imagem 2 %32
    • Disconnect the display cable from the motherboard with a plastic opening tool.
  11. Asus ZenBook UX303U Motherboard Fan Replacement: passo 11, imagem 1 %32 Asus ZenBook UX303U Motherboard Fan Replacement: passo 11, imagem 2 %32
    • Remove the three 6mm Phillips #00 screws from the hinge.
    • Remove the 2mm Phillips #00 screw from the plastic housing securing the fan into place.
  12. Asus ZenBook UX303U Motherboard Fan Replacement: passo 12, imagem 1 %32 Asus ZenBook UX303U Motherboard Fan Replacement: passo 12, imagem 2 %32
    • Lift the bottom of the laptop up slightly in order to unhinge the laptop.
    • Lift the screen assembly hinge up and off of the motherboard fan.
  13. Asus ZenBook UX303U Motherboard Fan Replacement: passo 13, imagem 1 %32 Asus ZenBook UX303U Motherboard Fan Replacement: passo 13, imagem 2 %32 Asus ZenBook UX303U Motherboard Fan Replacement: passo 13, imagem 3 %32
    • Using tweezers, disconnect the cable connector from the motherboard fan.
  14. Asus ZenBook UX303U Motherboard Fan Replacement: passo 14, imagem 1 %32 Asus ZenBook UX303U Motherboard Fan Replacement: passo 14, imagem 2 %32
    • Lift the fan up and off of the white pegs that secure it into place.
Conclusão
Uma outra pessoa concluiu este guia.
Luis Perez
Membro desde: 02/14/18
577 Reputação
2 Guias de autoria
Equipe
USF Tampa, Team S3-G5, Nance Spring 2018 Membro de USF Tampa, Team S3-G5, Nance Spring 2018
USFT-NANCE-S18S3G5
3 Membros
9 Guias de autoria
Um comentário
The bottom of the pictured device may feature Phillips #00 screws, but I also have this laptop and the screws around the edge of the bottom panel are Torx T5s on my device.
Nick Brennan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Duração total: 1,965
