Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the two round rubber feet at the hinge-edge of the laptop.
Remove the eleven 4 mm Phillips #00 screws from the back panel.
Using a plastic opening tool pry the back panel off of the laptop.
Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool.
Remove all seven 2 mm Phillips #00 screws from the battery.
Pull the speaker connector toward the edge of the laptop to disconnect it from its socket.
Lift the battery connector straight up off its socket to disconnect it from the motherboard.
Lift the battery and speakers up and pull out to remove.
16 outras pessoas executaram este guia.
11 comentários
hello where I can buy a UX303U battery for asus?
hello! Where I can buy a UX303U battery for my Asus netbook?
thanks
Just gone through this, but two problems surfaced. 1 it won’t connect to our usual WiFi router and can’t figure out why. Is it possible to damage the WiFi connectivity when removing battery? 2 there’s no indication of charge levels. It says 100% and doesn’t change. Thoughts?
Take all that back. Went back in and battery connector hadn’t clicked in far enough. Seems to be working fine now.
