Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will show you how to replace an old worn out or dead battery in an Asus ZenBook UX303U laptop.
O que você precisa
Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool.
16 outras pessoas executaram este guia.
11 comentários
hello where I can buy a UX303U battery for asus?
hello! Where I can buy a UX303U battery for my Asus netbook?
thanks
Just gone through this, but two problems surfaced. 1 it won’t connect to our usual WiFi router and can’t figure out why. Is it possible to damage the WiFi connectivity when removing battery? 2 there’s no indication of charge levels. It says 100% and doesn’t change. Thoughts?
Take all that back. Went back in and battery connector hadn’t clicked in far enough. Seems to be working fine now.
