Introdução
Removing the speaker module in the Asus ZenBook UX21e is relatively a simple process. By removing a few screws and prying off the housing, the speaker can be replaced in no time.
O que você precisa
Unscrew the bottom frame cover using the T4 Torx screwdriver by removing the eight 2mm screws around the frame.
Unscrew the two 7 mm screws at the top of the frame using the T4 Torx screwdriver.
Ferramenta utilizada nesse passo:Tweezers$3.99
Unplug the speaker wire from the motherboard with blunt or angled tweezers.
