Ir para o conteúdo principal
Asus ZenBook Flip UX360C Speaker Replacement
O que você precisa
  1. Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: passo 1, imagem 1 %32 Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: passo 1, imagem 2 %32 Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: passo 1, imagem 3 %32
    • Turn laptop over.
    • Use the metal spudger to pry rubber feet off in the four corners of laptop.
  2. Asus ZenBook Flip UX360C Speaker Replacement, Speaker: passo 2, imagem 1 %32
    • Attach an ESD wristband to your wrist and clip the grounding clamp to a grounded metal object.
  3. Asus ZenBook Flip UX360C Speaker Replacement: passo 3, imagem 1 %32
    • Remove all eleven 5 mm, Phillips #1 screws on the back cover.
  4. Asus ZenBook Flip UX360C Speaker Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to remove the keyboard panel.
  5. Asus ZenBook Flip UX360C Speaker Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to disconnect the ZIF keyboard ribbon cable from the motherboard.
  6. Asus ZenBook Flip UX360C Speaker Replacement: passo 6, imagem 1 %32 Asus ZenBook Flip UX360C Speaker Replacement: passo 6, imagem 2 %32 Asus ZenBook Flip UX360C Speaker Replacement: passo 6, imagem 3 %32
    • Use nylon-tipped tweezeres to detach the battery connection.
  7. Asus ZenBook Flip UX360C Speaker Replacement: passo 7, imagem 1 %32
    • Remove all ten Phillips #1 battery retaining screws.
  8. Asus ZenBook Flip UX360C Speaker Replacement: passo 8, imagem 1 %32
    • Using tweezers, carefully remove the connector connecting the speakers to the motherboard.
  9. Asus ZenBook Flip UX360C Speaker Replacement: passo 9, imagem 1 %32 Asus ZenBook Flip UX360C Speaker Replacement: passo 9, imagem 2 %32 Asus ZenBook Flip UX360C Speaker Replacement: passo 9, imagem 3 %32
    • Use your fingers or another object to slightly raise the bottom edge of the battery. The battery does not need to be fully removed to replace the speakers.
    • Use a nylon spudger or an opening tool to carefully pry the speaker from the chassis.
    • The speaker is held down with a mild adhesive. Work your way around the border to fully remove the speaker.
  10. Asus ZenBook Flip UX360C Speaker Replacement: passo 10, imagem 1 %32 Asus ZenBook Flip UX360C Speaker Replacement: passo 10, imagem 2 %32
    • Use tweezers to carefully unseat the cable connecting the left and right speakers.
  11. Asus ZenBook Flip UX360C Speaker Replacement: passo 11, imagem 1 %32 Asus ZenBook Flip UX360C Speaker Replacement: passo 11, imagem 2 %32 Asus ZenBook Flip UX360C Speaker Replacement: passo 11, imagem 3 %32
Conclusão
Kristopher Bright
Membro desde: 03/30/22
397 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 1-4, Harley Spring 2022 Membro de IUPUI, Team 1-4, Harley Spring 2022
IUPUI-HARLEY-S22S1G4
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 479
