Ir para o conteúdo principal
Asus ZenBook Flip UX360C Solid State Drive Replacement
O que você precisa
  1. Asus ZenBook Flip UX360C Solid State Drive Replacement, Solid State Drive: passo 1, imagem 1 %32
    • Attach an ESD wristband to your wrist and clip the grounding clamp to a grounded metal object.
  2. Asus ZenBook Flip UX360C Solid State Drive Replacement: passo 2, imagem 1 %32
    • Remove all eleven 5 mm Phillips #1 screws on the back cover.
  3. Asus ZenBook Flip UX360C Solid State Drive Replacement: passo 3, imagem 1 %32
    • Use plastic opening tools to remove the keyboard panel.
  4. Asus ZenBook Flip UX360C Solid State Drive Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to disconnect the ZIF keyboard ribbon cable from the motherboard.
  5. Asus ZenBook Flip UX360C Solid State Drive Replacement: passo 5, imagem 1 %32
    • Unscrew the 5 mm Phillips #1 retaining screw holding the SSD in place.
    • Carefully remove the SSD.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 44
Duração total: 3,360
