Ir para o conteúdo principal
Asus ZenBook Flip UX360C Screen Replacement
O que você precisa
  1. Asus ZenBook Flip UX360C Screen Replacement, Screen: passo 1, imagem 1 %32 Asus ZenBook Flip UX360C Screen Replacement, Screen: passo 1, imagem 2 %32
    • Use a spudger to pry out the two rubber grommets from the front of the screen.
    • Remove the two 4mm Phillips Head #1 screws behind the grommets.
  2. Asus ZenBook Flip UX360C Screen Replacement: passo 2, imagem 1 %32
    • Use a large plastic opening tool to work around the outside of the screen and gently separate the two halves.
  3. Asus ZenBook Flip UX360C Screen Replacement: passo 3, imagem 1 %32
    • Remove the two 2 mm Phillips #00 camera screws.
    • Remove the 2 mm Phillips #0 upper circuit board screw.
    • Remove the 2 mm Phillips #0 lower circuit board screw.
  4. Asus ZenBook Flip UX360C Screen Replacement: passo 4, imagem 1 %32 Asus ZenBook Flip UX360C Screen Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to unplug the two ribbon cables from the top half of the screen.
    • Detach the upper circuit board cable using the same method.
  5. Asus ZenBook Flip UX360C Screen Replacement: passo 5, imagem 1 %32 Asus ZenBook Flip UX360C Screen Replacement: passo 5, imagem 2 %32 Asus ZenBook Flip UX360C Screen Replacement: passo 5, imagem 3 %32
    • On the bottom half of the screen remove the screen connection.
    • Disconnect the lower circuit board cable.
    • Separate the wiring from the casing, and remove the screen.
Conclusão
Kristopher Bright
Membro desde: 03/30/22
397 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 1-4, Harley Spring 2022 Membro de IUPUI, Team 1-4, Harley Spring 2022
IUPUI-HARLEY-S22S1G4
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 34
Duração total: 1,914
