Ir para o conteúdo principal
Asus ZenBook Flip UX360C Keyboard Assembly Replacement
O que você precisa
  1. Asus ZenBook Flip UX360C Keyboard Assembly Replacement, Rubber Feet: passo 1, imagem 1 %32 Asus ZenBook Flip UX360C Keyboard Assembly Replacement, Rubber Feet: passo 1, imagem 2 %32 Asus ZenBook Flip UX360C Keyboard Assembly Replacement, Rubber Feet: passo 1, imagem 3 %32
    • Turn laptop over.
    • Use the metal spudger to pry rubber feet off in the four corners of laptop.
  2. Asus ZenBook Flip UX360C Keyboard Assembly Replacement, Keyboard Assembly: passo 2, imagem 1 %32
    • Flip device upside down, and remove the eleven 5 mm #1 Phillips case screws.
  3. Asus ZenBook Flip UX360C Keyboard Assembly Replacement: passo 3, imagem 1 %32
    • Flip the device back over.
    • Insert an opening tool between the keyboard assembly and bottom casing, and slide it around the edge to pop the keyboard assembly free.
  4. Asus ZenBook Flip UX360C Keyboard Assembly Replacement: passo 4, imagem 1 %32
    • Disconnect the keyboard ribbon cable from the motherboard.
Conclusão
Kristopher Bright
Membro desde: 03/30/22
397 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 1-4, Harley Spring 2022 Membro de IUPUI, Team 1-4, Harley Spring 2022
IUPUI-HARLEY-S22S1G4
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 564
