Ir para o conteúdo principal
Asus ZenBook Flip UX360C Battery Replacement
O que você precisa
  1. Asus ZenBook Flip UX360C Battery Replacement, Battery: passo 1, imagem 1 %32
    • Attach an ESD wristband to your wrist and clip the grounding clamp to a grounded metal object.
  2. Asus ZenBook Flip UX360C Battery Replacement: passo 2, imagem 1 %32
    • Remove all eleven 5 mm, Phillips #1 screws on the back cover.
  3. Asus ZenBook Flip UX360C Battery Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to remove the keyboard panel.
  4. Asus ZenBook Flip UX360C Battery Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to disconnect the ZIF keyboard ribbon cable from the motherboard.
  5. Asus ZenBook Flip UX360C Battery Replacement: passo 5, imagem 1 %32 Asus ZenBook Flip UX360C Battery Replacement: passo 5, imagem 2 %32 Asus ZenBook Flip UX360C Battery Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Detach the battery connection using plastic tweezers.
  6. Asus ZenBook Flip UX360C Battery Replacement: passo 6, imagem 1 %32
    • Remove all ten Phillips #1 battery retaining screws.
  7. Asus ZenBook Flip UX360C Battery Replacement: passo 7, imagem 1 %32 Asus ZenBook Flip UX360C Battery Replacement: passo 7, imagem 2 %32 Asus ZenBook Flip UX360C Battery Replacement: passo 7, imagem 3 %32
    • Apply gentle pressure upwards to the electrical board with a plastic opening tool while lifting the battery to remove.
    • Insert a new battery.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 74
Duração total: 7,120
