Introdução
Use this guide to replace the Asus Zen AiO Pro Z240IC's motherboard to fix boot-up issues. No prior knowledge is required. All you need is a Phillips head screwdriver and plastic opening tools.
O que você precisa
Use the plastic opening tool to pry off the black plastic strip at the bottom of the screen by wiggling the tool between the strip and the screen.
Run the opening tool slowly along the base of the screen, peeling the black strip back, until the opposite end of the screen is reached.
Place the computer on its back, facing up.
Wedge the plastic opening tool in between the screen and the bezel of the aluminum computer casing.
Move the tool along the entire edge of the screen with an up-and-down prying motion to loosen the screen from the casing. Do not lift the entire screen away from the computer yet.
Locate the WLAN card in the upper left hand corner of the computer.
Use a Phillips #1 screwdriver to remove the 3.2 mm screw on the top of the WLAN card.
Use a Phillips #0 screwdriver to remove the three (3) 4.8 mm screws from the fan unit.
Remove the cable connecting the fan to the motherboard by pulling the cable out of its socket.
Remove the six (6) ribbon cables by lifting up on the plastic locking tabs and then slipping the cables out of their sockets.
Remove the other two (2) cables by pulling straight out on the white connectors.
4 outras pessoas executaram este guia.
7 comentários
I have been trying and failing to reset the BIOS completely as for some reason i have misslayed the password i set when i first purchsed it, i cannot boot to the OS without it. i have already tried removing the battery and leaving over night to try and reset but that has also failed. is there anyway i can remove the password? or how the locate the cmos jumpers which for the life of me i cannot find.
MY piece of crap Z240IC decided not to start yesterday. Beyond 1 year warranty (barely), and can’t find a replacement working motherboard to swap with. The power supply (cord) went out 6 months ago. I believe when this happened, something may have damaged one of the circuits, as the machine has slowly shown issues of failing parts. I can’t believe I spent so much on this “iMac Killer” and yet it never lived up to it’s proclaimed reputation, nor is it built to last. It looks like we’re all pretty screwed here.
David Mills you can buy one at http://www.buy-motherboard.co.uk/laptop-....
