Ir para o conteúdo principal
Asus Z54C-JS31 Keyboard Replacement
O que você precisa
  1. Asus Z54C-JS31 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Asus Z54C-JS31 Keyboard Replacement, Battery: passo 1, imagem 2 %32 Asus Z54C-JS31 Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 Keyboard Replacement, Keyboard: passo 2, imagem 1 %32 Asus Z54C-JS31 Keyboard Replacement, Keyboard: passo 2, imagem 2 %32
    • Turn the laptop to its normal position and open the display to show the keyboard.
    • Gently push back the five tabs holding the keyboard down using the plastic opening tool.
  3. Asus Z54C-JS31 Keyboard Replacement: passo 3, imagem 1 %32 Asus Z54C-JS31 Keyboard Replacement: passo 3, imagem 2 %32 Asus Z54C-JS31 Keyboard Replacement: passo 3, imagem 3 %32
    • Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out.
Conclusão
Mark DeSimone
Membro desde: 10/19/17
801 Reputação
Autoria de 8 guias
Equipe
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 Membro de UMass Dartmouth, Team S3-G1, Bailey Fall 2017
UMASSD-BAILEY-F17S3G1
Membros da 2
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 163
