Ir para o conteúdo principal
Asus Z54C-JS31 Hard Drive Replacement
O que você precisa
  1. Asus Z54C-JS31 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Asus Z54C-JS31 Hard Drive Replacement, Battery: passo 1, imagem 2 %32 Asus Z54C-JS31 Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 Hard Drive Replacement, HDD/RAM Cover Panel: passo 2, imagem 1 %32 Asus Z54C-JS31 Hard Drive Replacement, HDD/RAM Cover Panel: passo 2, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
  3. Asus Z54C-JS31 Hard Drive Replacement: passo 3, imagem 1 %32 Asus Z54C-JS31 Hard Drive Replacement: passo 3, imagem 2 %32
    • Slide the back panel off by placing a hand on each corner and pulling the panel towards you.
  4. Asus Z54C-JS31 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Asus Z54C-JS31 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • Remove the four 9mm screws holding the hard drive in place.
  5. Asus Z54C-JS31 Hard Drive Replacement: passo 5, imagem 1 %32 Asus Z54C-JS31 Hard Drive Replacement: passo 5, imagem 2 %32 Asus Z54C-JS31 Hard Drive Replacement: passo 5, imagem 3 %32
    • Slide the hard drive to the left to disconnect it.
    • Then pull on the black tab to lift the hard drive out of the laptop.
Conclusão
Mark DeSimone
Membro desde: 10/19/17
801 Reputação
Autoria de 8 guias
Equipe
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 Membro de UMass Dartmouth, Team S3-G1, Bailey Fall 2017
UMASSD-BAILEY-F17S3G1
Membros da 2
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 117
