Ir para o conteúdo principal
Asus X751MA-DH01TQ Screen Replacement
O que você precisa
  1. Asus X751MA-DH01TQ Screen Replacement, Screen: passo 1, imagem 1 %32 Asus X751MA-DH01TQ Screen Replacement, Screen: passo 1, imagem 2 %32
    • Turn the laptop upside down.
    • Unscrew the 10 screws on the bottom of the laptop using a PH00 screwdriver bit.
  2. Asus X751MA-DH01TQ Screen Replacement: passo 2, imagem 1 %32 Asus X751MA-DH01TQ Screen Replacement: passo 2, imagem 2 %32 Asus X751MA-DH01TQ Screen Replacement: passo 2, imagem 3 %32
    • Use a plastic opening tool to detach and take off the keyboard.
  3. Asus X751MA-DH01TQ Screen Replacement: passo 3, imagem 1 %32 Asus X751MA-DH01TQ Screen Replacement: passo 3, imagem 2 %32 Asus X751MA-DH01TQ Screen Replacement: passo 3, imagem 3 %32
    • Remove the eight 5.5 Phillips #00 screws located at the top right and left hand side of panel.
    • There are four screws on each side.
  4. Asus X751MA-DH01TQ Screen Replacement: passo 4, imagem 1 %32 Asus X751MA-DH01TQ Screen Replacement: passo 4, imagem 2 %32 Asus X751MA-DH01TQ Screen Replacement: passo 4, imagem 3 %32
    • Remove the four 4mm Phillips #00 screws on the bottom left and right of the screen.
    • There are two screws on each side.
  5. Asus X751MA-DH01TQ Screen Replacement: passo 5, imagem 1 %32
    • Insert the plastic opening tool on the side of the screen and slide it all the way around to open the screen up.
  6. Asus X751MA-DH01TQ Screen Replacement: passo 6, imagem 1 %32 Asus X751MA-DH01TQ Screen Replacement: passo 6, imagem 2 %32 Asus X751MA-DH01TQ Screen Replacement: passo 6, imagem 3 %32
    • Remove the cords on the left and right side of the screen.
  7. Asus X751MA-DH01TQ Screen Replacement: passo 7, imagem 1 %32 Asus X751MA-DH01TQ Screen Replacement: passo 7, imagem 2 %32 Asus X751MA-DH01TQ Screen Replacement: passo 7, imagem 3 %32
    • Remove the eight total screws (4 on each side) that are on the side of the white part on the back of the screen.
  8. Asus X751MA-DH01TQ Screen Replacement: passo 8, imagem 1 %32 Asus X751MA-DH01TQ Screen Replacement: passo 8, imagem 2 %32 Asus X751MA-DH01TQ Screen Replacement: passo 8, imagem 3 %32
    • Remove the two 4mm Phillips #00 screws on the top corners of the back of the screen.
    • Remove the metal bars that you have just unscrewed.
  9. Asus X751MA-DH01TQ Screen Replacement: passo 9, imagem 1 %32 Asus X751MA-DH01TQ Screen Replacement: passo 9, imagem 2 %32
    • Peel back the bronze sticker that is connecting the white border piece to the outside edge of the screen.
  10. Asus X751MA-DH01TQ Screen Replacement: passo 10, imagem 1 %32
    • Use the plastic opening tool to pry open the white part away from the screen.
  11. Asus X751MA-DH01TQ Screen Replacement: passo 11, imagem 1 %32 Asus X751MA-DH01TQ Screen Replacement: passo 11, imagem 2 %32
    • Pull the white part out and pull out the rest of the screen.
Conclusão
Collen Bleigh
Membro desde: 09/18/18
198 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 475
