Ir para o conteúdo principal
Asus X751MA-DH01TQ Web Cam Replacement
O que você precisa
  1. Asus X751MA-DH01TQ  Web Cam Replacement, Web Cam: passo 1, imagem 1 %32 Asus X751MA-DH01TQ  Web Cam Replacement, Web Cam: passo 1, imagem 2 %32
    • Turn the laptop upside down and locate the ten screws that hold the plate cover.
    • Remove all ten screws using a 00 Phillips head screwdriver.
  2. Asus X751MA-DH01TQ  Web Cam Replacement: passo 2, imagem 1 %32 Asus X751MA-DH01TQ  Web Cam Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tool, pry the keyboard off of the base of the laptop.
    • Lift up and remove the keyboard.
  3. Asus X751MA-DH01TQ  Web Cam Replacement: passo 3, imagem 1 %32 Asus X751MA-DH01TQ  Web Cam Replacement: passo 3, imagem 2 %32 Asus X751MA-DH01TQ  Web Cam Replacement: passo 3, imagem 3 %32
    • Remove eight 4.4 Phillips #00 screws attached to the hinge.
    • Hold the screen so it wont fall over.
  4. Asus X751MA-DH01TQ  Web Cam Replacement: passo 4, imagem 1 %32 Asus X751MA-DH01TQ  Web Cam Replacement: passo 4, imagem 2 %32 Asus X751MA-DH01TQ  Web Cam Replacement: passo 4, imagem 3 %32
    • Remove the stickers from the bottom left and right corners of the screen.
    • Use a 00 Phillips head screw driver to remove the four screws.
  5. Asus X751MA-DH01TQ  Web Cam Replacement: passo 5, imagem 1 %32
    • Use the plastic opening tool to take the screen apart.
  6. Asus X751MA-DH01TQ  Web Cam Replacement: passo 6, imagem 1 %32 Asus X751MA-DH01TQ  Web Cam Replacement: passo 6, imagem 2 %32
    • Remove the two 4mm Phillips #00 screws attached to the webcam.
  7. Asus X751MA-DH01TQ  Web Cam Replacement: passo 7, imagem 1 %32 Asus X751MA-DH01TQ  Web Cam Replacement: passo 7, imagem 2 %32 Asus X751MA-DH01TQ  Web Cam Replacement: passo 7, imagem 3 %32
    • Slowly pull up the webcam out of its slot, and begin to remove the wire.
  8. Asus X751MA-DH01TQ  Web Cam Replacement: passo 8, imagem 1 %32 Asus X751MA-DH01TQ  Web Cam Replacement: passo 8, imagem 2 %32
    • Continue to unravel the wire and peel the webcam wire sticker off.
  9. Asus X751MA-DH01TQ  Web Cam Replacement: passo 9, imagem 1 %32 Asus X751MA-DH01TQ  Web Cam Replacement: passo 9, imagem 2 %32
    • Once the sticker is peeled off pull the plug holding the webcam into the circuit board and the webcam is now disconnected.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 165
