Introdução
This guide will assist you in replacing a faulty wireless card in your ASUS X751L.
O que você precisa
With the screen closed, place your laptop upside-down with the front facing you.
Remove the six 14.6mm Phillips #00 screws.
Remove the four 6.6mm Phillips #00 screws.
Remove the single 4.7mm PH00 screw holding the wireless card to the motherboard.
3 outras pessoas executaram este guia.
