Introdução
We will show you how to open the laptop and change / upgrade the HDD (hard disk drive).
O que você precisa
Vídeo de Apresentação
Switch off the Laptop and remove the Battery.
Unscrew the two Philips screws and remove the HDD / RAM Cover.
Remove the two Philips screws and separate the HDD from the caddy case.
You can install 2.5" SATA HDD, 5400rpm / 7200rpm, 320GB / 500GB / 750GB /1TB.
Did you do it successfully.
Okay so I was needing to upgrade hdd on this exact model and it worked great for the first part but putting the cover on didn’t work any ideas?
4 outras pessoas executaram este guia.
Um comentário
Were do you get the OS already installed on the drive. I have a Asus 550 with a 500 G and win 8.1. Looking to up grade to win 10 YES i have the GEO FORCE graphic card. Will I loose the use of the GEO FORCE. card. It has a i7 chip. And 6 g of line one cache would like to take to like 16 G… I would like to use the solid state hard drive. I understand it weathers bounces. Small slams and bangs better than the disc type. But I may not beable to afford this high a upgrade. Recommendations chrisdeiotte7@gmail.com
