Introdução
How to upgrade the Laptop memory.
_______________ Video manual: _______________
O que você precisa
Vídeo de Apresentação
Switch off the Laptop and remove the Battery.
Remove two screws securing the HDD / RAM (service) cover.
Remove the cover.
This Laptop has 2 GB or 4 GB DDR3 1333/1600 MHz SDRAM OnBoard memory and 1 x SO-DIMM socket for expansion up to 6 GB or 8 GB SDRAM
You can install only one DDR3 SDRAM Module, maximum 4 GB.
Did you do it successfully.
5 outras pessoas executaram este guia.
