Ir para o conteúdo principal
Asus X553MA-BPD07051 Hard Drive Replacement
O que você precisa
Vídeo de Apresentação
  1. Asus X553MA-BPD07051 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Asus X553MA-BPD07051 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
  2. Asus X553MA-BPD07051 Hard Drive Replacement: passo 2, imagem 1 %32
    • Lift the edges of the keyboard using the plastic iFixit opening tool and raise the keyboard slightly to see the inside of the laptop.
    • Do not lift the keyboard too high as the keyboard is connected to the motherboard by two ribbon connectors that must be detached.
  3. Asus X553MA-BPD07051 Hard Drive Replacement: passo 3, imagem 1 %32 Asus X553MA-BPD07051 Hard Drive Replacement: passo 3, imagem 2 %32
    • Lift back the clip on the ribbon tape, and pull the tape out in order to remove the keyboard from the laptop.
    • Remove both pieces of the ribbon tape connecting the keyboard to the motherboard.
  4. Asus X553MA-BPD07051 Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the bundled cable connector attaching the battery to the motherboard with the plastic iFixit opening tool.
    • Make sure that you do not remove the entire connector by applying too much force. Only the white plastic connector should be removed from the metal part on the motherboard.
    The silver metal piece slides up (towards the monitor) to unlock the white plastic to lift up
    Wolphin - Responder
  5. Asus X553MA-BPD07051 Hard Drive Replacement: passo 5, imagem 1 %32 Asus X553MA-BPD07051 Hard Drive Replacement: passo 5, imagem 2 %32
    • Use Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws attaching the battery to the laptop.
  6. Asus X553MA-BPD07051 Hard Drive Replacement: passo 6, imagem 1 %32 Asus X553MA-BPD07051 Hard Drive Replacement: passo 6, imagem 2 %32
    • Lift the battery up and remove it completely from the laptop.
  7. Asus X553MA-BPD07051 Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32 Asus X553MA-BPD07051 Hard Drive Replacement, Hard Drive: passo 7, imagem 2 %32
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws that are securing the hard drive.
  8. Asus X553MA-BPD07051 Hard Drive Replacement: passo 8, imagem 1 %32 Asus X553MA-BPD07051 Hard Drive Replacement: passo 8, imagem 2 %32
    • Lift the hard drive up and pull it towards the screen so that it disconnects from the motherboard.
    • Use caution when disconnecting the hard drive from the motherboard, so that neither connector gets broken.
Conclusão
Equipe
UMass Dartmouth, Team S1-G4, Botvin Fall 2019 Membro de UMass Dartmouth, Team S1-G4, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G4
Membros da 3
Autoria de 5 guias
2 comentários
Thanks. Step 4 cost me time and money because this guide isn’t full. You need to move metal bracket before disconnecting the battery otherwise there’s no way to remove it without tearing whole connector. @%^$$@$#!
ryuuganhp - Responder
ryuuganhp, thanks for your comment. Very important and helpful.
Łukasz Szwykowski - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 1,528
