Introdução
The touch pad controls cursor movement and is one of the most used parts of the laptop. It is exposed to frequent wear and tear and may need replacement.
O que você precisa
Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
Two 4.3 mm screws in the back corners
One 17.5 mm screw at the left edge near the optical drive
Three 4.3 mm screws in the front edge
Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
Flip over the keyboard plate cover so the keys are facing down to locate the back of the touch pad.
6 outras pessoas executaram este guia.
6 comentários
why on earth would you do all that do change the touchpad?
it would be step 1,2,3,4,5,21,22,23
I agree with Mr Serra - you wouldn't need to touch the Motherboard/hard drive.
People, if you take just two seconds to think about it, the process described is plainly one that shows how to remove ALL the parts, and all you have to do is take note of the ones that are relevant to what you want to do, and ignore the rest.
Can't believe you are whining about being given extra FREE information that you might want in the future.
Too quick to criticise.
