Introdução
The Asus X551CA power button allows the laptop to turn on and off. If it is broken, the laptop will not receive the signal to boot up.
O que você precisa
Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
Two 4.3 mm screws in the back corners
One 17.5 mm screw at the left edge near the optical drive
Three 4.3 mm screws in the front edge
Invert the laptop in order to gain access to the ribbons.
Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
Yes and you have to put lotion on
Now, that is a stupid question! Of course! As I am working on 551M, I naturally have to have nails painted orange, with blue accents!
that boy ain't right
Locate the power button in the corner of the keyboard plate cover.
Disconnect the ribbon from the small green board by flipping up the small white flap and pulling parallel to the green board's surface.
7 outras pessoas executaram este guia.
screw assignments are definitely wrong. I swapped the red and the green, as per comment above, and kept the blue as-is.
jasonbuechler - Responder
jason is right
starwilson - Responder
correct, swap the green and red
Josh - Responder
Jason is correct
Clem Lanoe - Responder
Thanks everyone. It does seem like someone got their screws mixed up when they wrote this guide. I’ve made some changes as you all suggested, so the screw placements should be more accurate now. If anyone with this laptop could verify the screw measurements with a digital caliper, that’d also be very helpful.
Jeff Suovanen - Responder
