Introdução
This guide will walk you through a hard drive replacement in the Asus X550ZA-SA100603E which can upgrade computer speed and reduce mechanical failures.
Hard drives can fail over time due to heat, physical damage, humidity, dust, power surges, or from age and may need to be replaced every 7-10 years. Replacement may be required if the current drive has expired or has experienced hardware failure. Replacement can also be performed to increase computer speed and capacity.
Check the user manual to ensure the replacement drive is compatible. The user manual can be found at the ASUS website.
Remember to back up any important data from the old hard drive before removal.
No special skills are required to perform this repair.
O que você precisa
Remove all of the 10 bottom case screws.
Seven of them are 14 mm screws.
Three of them are 4 mm screws.
Um comentário
There are steps omitted since the unit shown was already disassembled.
During Step 3: There will be four delicate ribbon cables, three connecting the Keyboard and one connecting the USB to the Motherboard that has adhesive and will be stuck to the drive, they all need to be carefully unplugged from the Motherboard.
Step 3.5: Four 4mm screws will be holding the drive tray in place and will have to be removed.
