Ir para o conteúdo principal
Asus X550ZA-SA100603E Battery Replacement
O que você precisa
  1. Asus X550ZA-SA100603E Battery Replacement, Keyboard: passo 1, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the seven 14 mm screws on the bottom of the laptop.
    • Then use the Phillips #0 to remove the three 4 mm screws on the bottom of the laptop.
  2. Asus X550ZA-SA100603E Battery Replacement: passo 2, imagem 1 %32 Asus X550ZA-SA100603E Battery Replacement: passo 2, imagem 2 %32 Asus X550ZA-SA100603E Battery Replacement: passo 2, imagem 3 %32
    • Insert a plastic opening tool between the keyboard and base of the laptop to pry the keyboard away from the base. Do this around the entire perimeter of the laptop.
    • This disconnects the face of the keyboard. Gently lift the keyboard up to expose the motherboard.
    • There are still ribbon cables connecting the keyboard face to the motherboard. Do not pull the keyboard away roughly.
  3. Asus X550ZA-SA100603E Battery Replacement: passo 3, imagem 1 %32 Asus X550ZA-SA100603E Battery Replacement: passo 3, imagem 2 %32 Asus X550ZA-SA100603E Battery Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Gently lift the keyboard to access the three ribbon cables connected to the motherboard
    • Using precision tweezers, flip up the white and black retaining flaps on the ZIF connectors that hold the two smaller ribbon cables in place.
    • Gently pull the ribbon cables from their sockets on the motherboard.
  4. Asus X550ZA-SA100603E Battery Replacement: passo 4, imagem 1 %32 Asus X550ZA-SA100603E Battery Replacement: passo 4, imagem 2 %32 Asus X550ZA-SA100603E Battery Replacement: passo 4, imagem 3 %32
    • Push the two white clamps on the large ZIF connector towards the screen.
    • Gently remove the track pad ribbon cable from its connector.
  5. Asus X550ZA-SA100603E Battery Replacement: passo 5, imagem 1 %32
    • Remove the keyboard.
  6. Asus X550ZA-SA100603E Battery Replacement, Battery: passo 6, imagem 1 %32 Asus X550ZA-SA100603E Battery Replacement, Battery: passo 6, imagem 2 %32
    • Disconnect the multi-wire battery plug from the motherboard.
  7. Asus X550ZA-SA100603E Battery Replacement: passo 7, imagem 1 %32 Asus X550ZA-SA100603E Battery Replacement: passo 7, imagem 2 %32 Asus X550ZA-SA100603E Battery Replacement: passo 7, imagem 3 %32
    • Pull the two tabs holding the battery in place and lift the battery up. It should remove easily.
Conclusão
6 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 6,154
