Ir para o conteúdo principal
Asus X540S panel Disassembly
O que você precisa
    • Open the Optical Drive to allow removal of keyboard before powering down computer.
  1. Asus X540S panel Disassembly: passo 2, imagem 1 %32
    • Remove the two 15mm Philips #1 screws.
    • Remove the two 12mm Philips #1 screws.
    • Remove the six 9mm Philips #1 screws.
  2. Asus X540S panel Disassembly: passo 3, imagem 1 %32 Asus X540S panel Disassembly: passo 3, imagem 2 %32 Asus X540S panel Disassembly: passo 3, imagem 3 %32
    • Lift the side of the top.
    • Remove the keyboard cable.
    • Remove the trackpad cable.
    • Lift the release tabs on the keyboard/trackpad connectors
Conclusão
13 outras pessoas executaram este guia.
Padraic Hoselton
Membro desde: 08/22/17
4.180 Reputação
Autoria de 12 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.528 guias
3 comentários
Feels like the panel is glued on mine. all screws are out, corners are loose but rest feels glued. anybody have advice? I dont have access to a heatgun
Non Gerrell - Responder
Well the first time I did it I had to give it a bit more pressure and loosen it up on all the sides. Because it should only be snapped in place. I don’t remember mine having glue the first time but I do remember I needed pry tools to get it off. I used some ifixit spudgers.
Padraic Hoselton -
I used a plastic card (like credit card) to slide between the panels along the edge - it went smooth!
Alexey Sazonov -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 49
Duração total: 10,117
