Introdução
This guide will show you how to remove the hard drive on an Asus X540S notebook.
O que você precisa
Open the Optical Drive to allow removal of keyboard before powering down computer.
Lift the side of the top.
Remove the keyboard cable.
Remove the trackpad cable.
When removing both cables there is a small black plastic flap covering the connection.
GENTLY lift that flap and GENTLY lift the end of the cable/ribbon and you're good to go.
My first try I was under the impression it was more of a plug and didn't see any specifics just like above “remove cable” but no description of how.
Even though I did it wrong, it didn't damage anything, and this guide was a big help.
Added a note. Thanks for the comment!
While lifting the lid, it's useful to have a spudger to detach the snaps from the top
Remove the four Philips #1 screws.
Wanted to add:
Must open dvd drawer first to pull up on top housing
Can only spudge after pulling up on top above DVD opening - stiff expired credit card works good
No hidden screws, the ones on the bottom are it
Only 2 ribbon cables, keyboard and touchpad
Ribbon cables are short, keeping plastic clamps secured on them tricky when reassembling
Very helpful guide, thank you :)
18 outras pessoas executaram este guia.
7 comentários
Looks simple enough Padraic. Thanks. Does a new install of win10 come already copied in a new HDD? Would this replacement be and different if I used a digital drive? (My old hd failed and I have no system).
After installing an OEM replacement HDD in my x540, I bought a flash drive on Amazon for$10 that rebooted my Windows 10 and it's working like a brand new machine.
I believe the product key for windows 10 is embedded in motherboard.
F S -
Hi … How can a flashdrive reboot a Win10 on a new SDD /HDD ? A Windows flash drive contains a Win10 bootable ISO ?
On Amazon, I found flash drives with a product key but I don’t know where the new installation can be done from if there is no ISO on it …
(I have a x540 with a dead HDD …)
gnogno35 -
No problem!
I will add a note to the keyboard and trackpad on step 2
@paperboypaddy what hard drive did you use and what brand? Mine just bit the dust.
