Ir para o conteúdo principal
Asus X502C-RB01 Motherboard Replacement
O que você precisa
  1. Asus X502C-RB01 Motherboard Replacement, Keyboard Panel: passo 1, imagem 1 %32
    • Turn off the laptop and flip it face down.
    • Using a Phillips #0 screwdriver, remove the seven 9mm screws circled in red.
    • With the same screwdriver, remove the four 5mm screws circled in orange.
  2. Asus X502C-RB01 Motherboard Replacement: passo 2, imagem 1 %32
    • Flip the laptop face up and open the lid.
    • Use the plastic opening tool to pry around the entire edge of the keyboard panel to loosen the panel from the base.
    • Be careful not to lift the panel just yet, as it is still connected to the motherboard.
  3. Asus X502C-RB01 Motherboard Replacement: passo 3, imagem 1 %32 Asus X502C-RB01 Motherboard Replacement: passo 3, imagem 2 %32
    • Partially lift the panel up, revealing the two cables connected to the motherboard.
  4. Asus X502C-RB01 Motherboard Replacement: passo 4, imagem 1 %32 Asus X502C-RB01 Motherboard Replacement: passo 4, imagem 2 %32
    • Disconnect the first ZIF cable by lifting the tab using the spuger tool or your fingernail and gently pull the cable out.
    • Disconnect the second ZIF cable by lifting the tab using your fingernail and gently pull the cable out. This one is more difficult to reach with the spudger.
  5. Asus X502C-RB01 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the keyboard panel completely and set it aside. The internal components of the laptop are now exposed.
  6. Asus X502C-RB01 Motherboard Replacement, Hard Drive: passo 6, imagem 1 %32
    • Locate the hard drive in the area highlighted in red.
    • This demonstration model does not have a mounting bracket around the hard drive.
  7. Asus X502C-RB01 Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the four 5mm screws from the hard drive mounting bracket using the Phillips #0 screwdriver.
  8. Asus X502C-RB01 Motherboard Replacement: passo 8, imagem 1 %32
    • Slide the hard drive in the direction away from the connector and lift it up to remove it.
  9. Asus X502C-RB01 Motherboard Replacement, Motherboard: passo 9, imagem 1 %32
    • Unplug the battery from the laptop by lifting the connector up with the flat end of the spudger.
    • Unplug the two ZIF cables by lifting the tab using the spudger tool or your fingernail then pulling the cable out gently.
  10. Asus X502C-RB01 Motherboard Replacement: passo 10, imagem 1 %32
    • Unplug the bundled cable by pulling it away from the connector with a bit of force.
    • Unplug the display cable connector by lifting the tape and pulling it away from the connector.
    • Unplug the two antenna cables connected to the network interface card by prying it off with the flat end of the spudger.
  11. Asus X502C-RB01 Motherboard Replacement: passo 11, imagem 1 %32 Asus X502C-RB01 Motherboard Replacement: passo 11, imagem 2 %32
    • Remove the four 5.5mm screws using the Phillips #0 screwdriver.
  12. Asus X502C-RB01 Motherboard Replacement: passo 12, imagem 1 %32
    • Gently lift the motherboard out of the casing.
Conclusão
Jaspal Chauhan
Membro desde: 01/19/17
491 Reputação
Autoria de 4 guias
Equipe
UC Davis, Team 1-5, Rodger Winter 2017 Membro de UC Davis, Team 1-5, Rodger Winter 2017
UCD-RODGER-W17S1G5
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 24
Duração total: 988
