Introdução
If your hard drive has failed or needs to be replaced, this guide will show you how to get to the hard drive and remove it.
O que você precisa
Turn off the laptop and flip it face down.
Using a Phillips #0 screwdriver, remove the seven 9mm screws circled in red.
With the same screwdriver, remove the four 5mm screws circled in orange.
3 outras pessoas executaram este guia.
