Ir para o conteúdo principal
Asus X502C-RB01 Fan Replacement
O que você precisa
  1. Asus X502C-RB01 Fan Replacement, Keyboard Panel: passo 1, imagem 1 %32
    • Turn off the laptop and flip it face down.
    • Using a Phillips #0 screwdriver, remove the seven 9mm screws circled in red.
    • With the same screwdriver, remove the four 5mm screws circled in orange.
    Pergunte ao FixBot
  2. Asus X502C-RB01 Fan Replacement: passo 2, imagem 1 %32
    • Flip the laptop face up and open the lid.
    • Use the plastic opening tool to pry around the entire edge of the keyboard panel to loosen the panel from the base.
    • Be careful not to lift the panel just yet, as it is still connected to the motherboard.
    Pergunte ao FixBot
  3. Asus X502C-RB01 Fan Replacement: passo 3, imagem 1 %32 Asus X502C-RB01 Fan Replacement: passo 3, imagem 2 %32
    • Partially lift the panel up, revealing the two cables connected to the motherboard.
    Pergunte ao FixBot
  4. Asus X502C-RB01 Fan Replacement: passo 4, imagem 1 %32 Asus X502C-RB01 Fan Replacement: passo 4, imagem 2 %32
    • Disconnect the first ZIF cable by lifting the tab using the spuger tool or your fingernail and gently pull the cable out.
    • Disconnect the second ZIF cable by lifting the tab using your fingernail and gently pull the cable out. This one is more difficult to reach with the spudger.
    Pergunte ao FixBot
  5. Asus X502C-RB01 Fan Replacement: passo 5, imagem 1 %32
    • Remove the keyboard panel completely and set it aside. The internal components of the laptop are now exposed.
    Pergunte ao FixBot
  6. Asus X502C-RB01 Fan Replacement, Hard Drive: passo 6, imagem 1 %32
    • Locate the hard drive in the area highlighted in red.
    • This demonstration model does not have a mounting bracket around the hard drive.
    Pergunte ao FixBot
  7. Asus X502C-RB01 Fan Replacement: passo 7, imagem 1 %32
    • Remove the four 5mm screws from the hard drive mounting bracket using the Phillips #0 screwdriver.
    Pergunte ao FixBot
  8. Asus X502C-RB01 Fan Replacement: passo 8, imagem 1 %32
    • Slide the hard drive in the direction away from the connector and lift it up to remove it.
    Pergunte ao FixBot
  9. Asus X502C-RB01 Fan Replacement, Motherboard: passo 9, imagem 1 %32
    • Unplug the battery from the laptop by lifting the connector up with the flat end of the spudger.
    • Unplug the two ZIF cables by lifting the tab using the spudger tool or your fingernail then pulling the cable out gently.
    Pergunte ao FixBot
  10. Asus X502C-RB01 Fan Replacement: passo 10, imagem 1 %32
    • Unplug the bundled cable by pulling it away from the connector with a bit of force.
    • Unplug the display cable connector by lifting the tape and pulling it away from the connector.
    • Unplug the two antenna cables connected to the network interface card by prying it off with the flat end of the spudger.
    Pergunte ao FixBot
  11. Asus X502C-RB01 Fan Replacement: passo 11, imagem 1 %32 Asus X502C-RB01 Fan Replacement: passo 11, imagem 2 %32
    • Remove the four 5.5mm screws using the Phillips #0 screwdriver.
    Pergunte ao FixBot
  12. Asus X502C-RB01 Fan Replacement: passo 12, imagem 1 %32
    • Gently lift the motherboard out of the casing.
    Pergunte ao FixBot
  13. Asus X502C-RB01 Fan Replacement, Fan: passo 13, imagem 1 %32
    • Flip the motherboard over so the fan is right side up.
    Pergunte ao FixBot
  14. Asus X502C-RB01 Fan Replacement: passo 14, imagem 1 %32
    • Disconnect the fan from the motherboard by pulling the power cable connector.
    Pergunte ao FixBot
  15. Asus X502C-RB01 Fan Replacement: passo 15, imagem 1 %32
    • Remove the two 5.5mm screws using a Phillips #0 head screwdriver.
    Pergunte ao FixBot
  16. Asus X502C-RB01 Fan Replacement: passo 16, imagem 1 %32
    • Detach the tape that connects the fan to the heatsink.
    Pergunte ao FixBot
  17. Asus X502C-RB01 Fan Replacement: passo 17, imagem 1 %32
    • Lift the fan off to remove it from the motherboard.
    Pergunte ao FixBot
Conclusão
Frances Tan
Membro desde: 01/19/17
143 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 1-5, Rodger Winter 2017 Membro de UC Davis, Team 1-5, Rodger Winter 2017
UCD-RODGER-W17S1G5
4 Membros
Autoria de 6 guias
1Comentário do guia
Great guide. Re: STEP 11 - my Asus notebook had 5 screws securing the mb.
u1oo - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 45
Ao todo: 1,076
