Introdução
The purpose of this guide is to show how to effectively remove the LCD. Please note that the screen is fragile and too much pressure applied will damage the screen.
O que você precisa
Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
Unscrew the six screws that hold the motherboard to the bottom of the laptop using a Phillips #00 screwdriver.
On the back of the motherboard there are two screws that attach the LCD connector to the motherboard.
Unscrew the two screws using the Phillips #00 screwdriver.
Pull the connector downwards and out.
The LCD connector does not require screws; the pictured component is the wifi card
To detach the hinges, use the Phillips #00 screwdriver to unscrew the two top screws on both the left and right hinges.
Lift the screen up off the back panel enough to have access to the LCD cable connector, but not all the way.
Pull the cable gently down and out of the connector to disconnect it.
Uma outra pessoa concluiu este guia.
Um comentário
Awesome write up. Thanks a bunch!
Couple amendments based off of my experience:
Step 12: There may be more screws on the far right side of the motherboard
Step 23: You have to split the plastic hinge protrusions to get the bezel off
