Introdução
This guide will demonstrate how to successfully replace the hinges in the Asus X501A-RH31 laptop. Please note there are small pieces of the motherboard connected to the hinges so execute caution when removing the hinges.
O que você precisa
Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
Unscrew the six screws that hold the motherboard to the bottom of the laptop using a Phillips #00 screwdriver.
To detach the hinges, use the Phillips #00 screwdriver to unscrew the two top screws on both the left and right hinges.
