Ir para o conteúdo principal
Asus X501A-RH31 Hinges Replacement
O que você precisa
  1. Asus X501A-RH31 Hinges Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over so that the back is facing upwards.
  2. Asus X501A-RH31 Hinges Replacement: passo 2, imagem 1 %32
    • To unlock the left tab, make sure the tab on the left has red showing.
  3. Asus X501A-RH31 Hinges Replacement: passo 3, imagem 1 %32 Asus X501A-RH31 Hinges Replacement: passo 3, imagem 2 %32
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
  4. Asus X501A-RH31 Hinges Replacement, Keyboard: passo 4, imagem 1 %32 Asus X501A-RH31 Hinges Replacement, Keyboard: passo 4, imagem 2 %32
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
  5. Asus X501A-RH31 Hinges Replacement: passo 5, imagem 1 %32
    • Turn the laptop over and open the top so the keyboard is facing you.
  6. Asus X501A-RH31 Hinges Replacement: passo 6, imagem 1 %32 Asus X501A-RH31 Hinges Replacement: passo 6, imagem 2 %32
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
  7. Asus X501A-RH31 Hinges Replacement: passo 7, imagem 1 %32
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
  8. Asus X501A-RH31 Hinges Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
  9. Asus X501A-RH31 Hinges Replacement, Fan: passo 9, imagem 1 %32
    • Unscrew the three screws using the Phillips #00 screwdriver.
    • The three screws are 5 mm in length, 4.2 mm in diameter.
  10. Asus X501A-RH31 Hinges Replacement: passo 10, imagem 1 %32
    • Unscrew the three screws on the left hand side of the big motherboard.
    • This will loosen the motherboard, which will allow for better access to the cables in the next step.
    • The three screws are 5 mm in length, 4.2 mm in diameter and Phillips head screws.
  11. Asus X501A-RH31 Hinges Replacement: passo 11, imagem 1 %32 Asus X501A-RH31 Hinges Replacement: passo 11, imagem 2 %32 Asus X501A-RH31 Hinges Replacement: passo 11, imagem 3 %32
    • Remove the connector cable attached to the bottom of the motherboard.
    • Take the black plastic spudger and press down on the lower half of the white plastic piece to remove the connector cable.
  12. Asus X501A-RH31 Hinges Replacement, Motherboard: passo 12, imagem 1 %32 Asus X501A-RH31 Hinges Replacement, Motherboard: passo 12, imagem 2 %32
    • Unscrew the six screws that hold the motherboard to the bottom of the laptop using a Phillips #00 screwdriver.
    • The six screws are 4.2 mm long, 5 mm in diameter.
  13. Asus X501A-RH31 Hinges Replacement: passo 13, imagem 1 %32 Asus X501A-RH31 Hinges Replacement: passo 13, imagem 2 %32
    Comprar
    • Unlatch the data cable by using tweezers to lift the white tab and release the cable.
  14. Asus X501A-RH31 Hinges Replacement: passo 14, imagem 1 %32 Asus X501A-RH31 Hinges Replacement: passo 14, imagem 2 %32
    • Remove the cable on the left side of the motherboard.
    • Use tweezers to pull the white tab up in order to release this cable.
  15. Asus X501A-RH31 Hinges Replacement: passo 15, imagem 1 %32
    • On the left side is a small piece of the motherboard. Unscrew the two screws holding this piece down with the Phillips #00 screwdriver.
    • The two screws are 6 mm long, 4.2 mm in diameter.
  16. Asus X501A-RH31 Hinges Replacement: passo 16, imagem 1 %32 Asus X501A-RH31 Hinges Replacement: passo 16, imagem 2 %32 Asus X501A-RH31 Hinges Replacement: passo 16, imagem 3 %32
    • Release the connector cable on the back right side of the motherboard.
    • Peel off the tape with tweezers so that the cable can be released.
    • Using the black plastic spudger, push the back half of the cable towards the screen.
  17. Asus X501A-RH31 Hinges Replacement: passo 17, imagem 1 %32 Asus X501A-RH31 Hinges Replacement: passo 17, imagem 2 %32
    • Grip the motherboard firmly and pull the board leftward and upwards so that the ports on the right side escape their frames.
  18. Asus X501A-RH31 Hinges Replacement: passo 18, imagem 1 %32 Asus X501A-RH31 Hinges Replacement: passo 18, imagem 2 %32
    • On the back of the motherboard there are two screws that attach the LCD connector to the motherboard.
    • Unscrew the two screws using the Phillips #00 screwdriver.
    • These screws are 3 mm in length, 3.5 mm in diameter.
    • Pull the connector downwards and out.
  19. Asus X501A-RH31 Hinges Replacement, Hinges: passo 19, imagem 1 %32
    • To detach the hinges, use the Phillips #00 screwdriver to unscrew the two top screws on both the left and right hinges.
    • The four screws are all the same. They are 6.2 mm in length, 4 mm in diameter.
  20. Asus X501A-RH31 Hinges Replacement: passo 20, imagem 1 %32
    • Once both sides of the laptop are unscrewed, gently pull the upper half of the laptop off of the bottom half.
  21. Asus X501A-RH31 Hinges Replacement: passo 21, imagem 1 %32 Asus X501A-RH31 Hinges Replacement: passo 21, imagem 2 %32
    • Use the black plastic spudger to pry off the black squares on the bottom of the laptop screen, this reveals two screws.
    • Take caution when removing these squares as they will bend and crease.
  22. Asus X501A-RH31 Hinges Replacement: passo 22, imagem 1 %32
    • Use the Phillips #00 screwdriver to unscrew the two screws at the bottom of the laptop screen.
    • The two screws are 6 mm long, 4mm in diameter.
  23. Asus X501A-RH31 Hinges Replacement: passo 23, imagem 1 %32
    • Place the black plastic spudger between the top cover of the screen and the bottom of the laptop frame that rests on the table.
    • Push down on the black plastic spudger to pry the top cover off the screen of the laptop.
    • The screen is fragile and too much pressure applied will damage the screen.
  24. Asus X501A-RH31 Hinges Replacement: passo 24, imagem 1 %32
    • At the bottom of the screen there are two screws on each hinge.
    • Unscrew the four screws using the Phillips #00 screwdriver.
    • The four screws are 3.5 mm long, 4.5 mm in diameter.
  25. Asus X501A-RH31 Hinges Replacement: passo 25, imagem 1 %32 Asus X501A-RH31 Hinges Replacement: passo 25, imagem 2 %32
    • At the top of the screen there are two screws on the left side and two screws on the right side of the laptop.
    • Using the Phillips head #00 screwdriver, unscrew the inside screw and then the outside screw.
    • All four screws are the same size. They are 4 mm in length, 4.2 mm in diameter.
Conclusão
Christopher
Membro desde: 10/19/17
359 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S3-G3, Bailey Fall 2017 Membro de UMass Dartmouth, Team S3-G3, Bailey Fall 2017
UMASSD-BAILEY-F17S3G3
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 18
Duração total: 631
