Ir para o conteúdo principal
Asus X501A-RH31 Fan Replacement
O que você precisa
  1. Asus X501A-RH31 Fan Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over so that the back is facing upwards.
    Pergunte ao FixBot
  2. Asus X501A-RH31 Fan Replacement: passo 2, imagem 1 %32
    • To unlock the left tab, make sure the tab on the left has red showing.
    Pergunte ao FixBot
  3. Asus X501A-RH31 Fan Replacement: passo 3, imagem 1 %32 Asus X501A-RH31 Fan Replacement: passo 3, imagem 2 %32
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
    Pergunte ao FixBot
  4. Asus X501A-RH31 Fan Replacement, Keyboard: passo 4, imagem 1 %32 Asus X501A-RH31 Fan Replacement, Keyboard: passo 4, imagem 2 %32
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
    Pergunte ao FixBot
  5. Asus X501A-RH31 Fan Replacement: passo 5, imagem 1 %32
    • Turn the laptop over and open the top so the keyboard is facing you.
    Pergunte ao FixBot
  6. Asus X501A-RH31 Fan Replacement: passo 6, imagem 1 %32 Asus X501A-RH31 Fan Replacement: passo 6, imagem 2 %32
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
    Pergunte ao FixBot
  7. Asus X501A-RH31 Fan Replacement: passo 7, imagem 1 %32
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
    Pergunte ao FixBot
  8. Asus X501A-RH31 Fan Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
    Pergunte ao FixBot
  9. Asus X501A-RH31 Fan Replacement, Fan: passo 9, imagem 1 %32
    • Unscrew the three screws using the Phillips #00 screwdriver.
    • The three screws are 5 mm in length, 4.2 mm in diameter.
    Pergunte ao FixBot
  10. Asus X501A-RH31 Fan Replacement: passo 10, imagem 1 %32
    • Unscrew the three screws on the left hand side of the big motherboard.
    • This will loosen the motherboard, which will allow for better access to the cables in the next step.
    • The three screws are 5 mm in length, 4.2 mm in diameter and Phillips head screws.
    Pergunte ao FixBot
  11. Asus X501A-RH31 Fan Replacement: passo 11, imagem 1 %32 Asus X501A-RH31 Fan Replacement: passo 11, imagem 2 %32 Asus X501A-RH31 Fan Replacement: passo 11, imagem 3 %32
    • Remove the connector cable attached to the bottom of the motherboard.
    • Take the black plastic spudger and press down on the lower half of the white plastic piece to remove the connector cable.
    Pergunte ao FixBot
Conclusão
Uma outra pessoa concluiu este guia.
Christopher
Membro desde: 10/19/17
371 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 55
Ao todo: 829
