Ir para o conteúdo principal
Asus X401A Processor Replacement
O que você precisa
  1. Asus X401A Processor Replacement, Processor: passo 1, imagem 1 %32 Asus X401A Processor Replacement, Processor: passo 1, imagem 2 %32
    • Turn your laptop off and unplug it from its charger prior to the repair to avoid electric shock.
    • Turn your laptop over, and press on the latches to remove the battery.
  2. Asus X401A Processor Replacement: passo 2, imagem 1 %32 Asus X401A Processor Replacement: passo 2, imagem 2 %32 Asus X401A Processor Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Unscrew the ten screws with a Phillips Head #1 screwdriver.
    • Eight screws are 3mm.
    • Two screws are 4mm.
    • Place the screws on a magnetic mat.
  3. Asus X401A Processor Replacement: passo 3, imagem 1 %32 Asus X401A Processor Replacement: passo 3, imagem 2 %32 Asus X401A Processor Replacement: passo 3, imagem 3 %32
    • Separate the keyboard from the back of the laptop with a plastic opening tool.
    • Do not completely separate the two pieces as there are ribbon cables that need to be disconnected.
    • When reassembling, you will hear snapping noises as the pieces connect together.
  4. Asus X401A Processor Replacement: passo 4, imagem 1 %32 Asus X401A Processor Replacement: passo 4, imagem 2 %32 Asus X401A Processor Replacement: passo 4, imagem 3 %32
    • Use a spudger to lift ZIF tabs up to disconnect the black and the white ribbon cable.
  5. Asus X401A Processor Replacement: passo 5, imagem 1 %32
    • Unscrew the ten 3mm screws with a Phillips Head #1 screwdriver,
  6. Asus X401A Processor Replacement: passo 6, imagem 1 %32
    • Use a spudger to lift the ZIF connector up to release the ribbon cable.
  7. Asus X401A Processor Replacement: passo 7, imagem 1 %32 Asus X401A Processor Replacement: passo 7, imagem 2 %32
    • Lift the connection between the screen and motherboard with a plastic spudger.
    • Remove the yellow and the clear tape.
  8. Asus X401A Processor Replacement: passo 8, imagem 1 %32
    • Disconnect the wire connecting the speakers.
  9. Asus X401A Processor Replacement: passo 9, imagem 1 %32 Asus X401A Processor Replacement: passo 9, imagem 2 %32 Asus X401A Processor Replacement: passo 9, imagem 3 %32
    • Lift the motherboard from the frame with a plastic spudger.
    • Set the frame of the laptop aside, and turn the motherboard over.
  10. Asus X401A Processor Replacement: passo 10, imagem 1 %32 Asus X401A Processor Replacement: passo 10, imagem 2 %32
    • Unscrew the four screws with a Phillips Head #1 screwdriver to disconnect the fan from the processor.
  11. Asus X401A Processor Replacement: passo 11, imagem 1 %32 Asus X401A Processor Replacement: passo 11, imagem 2 %32
    • Disconnect the cable connecting the fan to the motherboard.
    • Lift the fan part from the processor.
  12. Asus X401A Processor Replacement: passo 12, imagem 1 %32 Asus X401A Processor Replacement: passo 12, imagem 2 %32 Asus X401A Processor Replacement: passo 12, imagem 3 %32
    • Unscrew the screw holding the processor to the motherboard with a flathead screwdriver.
    • Lift the processor up away from the socket.
Conclusão
Tyler Stiles
Membro desde: 02/07/17
152 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-4, Wilder Spring 2017 Membro de Ohio State, Team 1-4, Wilder Spring 2017
OSU-WILDER-S17S1G4
Membros da 4
Autoria de 5 guias
Um comentário
Hi
What is the highest CPU I can put on it?
Does Asus X401A support i5-2450M?
mmaksat1988 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 1,834
