Introdução
This guide is a simple guide to replace a faulty cooling fan which could lead to your device running at a hotter temperature than usual.
O que você precisa
Remove the 9 1.2mm phillips head screws off the back of the computer using the small phillips head screw driver. Start by disconnecting the battery cable/ribbon.
Quase terminado!
Conclusão
