Ir para o conteúdo principal
Asus X202E-UH31T Cooling Fan Replacement
O que você precisa
  1. Asus X202E-UH31T Cooling Fan  Replacement, Cooling Fan: passo 1, imagem 1 %32
    • Remove the 9 1.2mm phillips head screws off the back of the computer using the small phillips head screw driver. Start by disconnecting the battery cable/ribbon.
  2. Asus X202E-UH31T Cooling Fan  Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to open the components of the laptop. In order to do this, insert the plastic opening tool in between the two covers then pry open with your fingers
  3. Asus X202E-UH31T Cooling Fan  Replacement: passo 3, imagem 1 %32
    • Locate the fan and take out the 5 1.2mm phillips head screws with the ifixit #0 small phillips head screw driver that hold the fan to the mother board.
    • Remove the fan and unplug the cable connector that connects the fan to the motherboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 768
