Introdução
If your AsusX202E does not turn on or looses power quickly use this guide to replace the battery.
O que você precisa
Remove the 9 1.2mm phillips head screws on the bottom of the computer using a small Phillips head screw driver.
To reassemble your device, follow these steps in reverse order.
Uma outra pessoa concluiu este guia.
