Ir para o conteúdo principal
Asus X200MA Wireless Card Replacement
O que você precisa
  1. Asus X200MA Wireless Card Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Wireless Card Replacement: passo 2, imagem 1 %32
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Wireless Card Replacement: passo 3, imagem 1 %32
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Wireless Card Replacement, Wireless Card: passo 4, imagem 1 %32
    • Take gold cap that connects to a black wire off using the metal spudger.
  5. Asus X200MA Wireless Card Replacement: passo 5, imagem 1 %32
    • Remove the following two screws:
    • Two 4 mm screws using Phillips #0 screwdriver.
  6. Asus X200MA Wireless Card Replacement: passo 6, imagem 1 %32
    • Slide the component up and out.
Conclusão
Vanessa Garcia
Membro desde: 01/22/15
1.763 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 21-24, Maness Winter 2015 Membro de Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
Membros da 4
Autoria de 8 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 4,051
