Ir para o conteúdo principal
Asus X200MA Motherboard Replacement
O que você precisa
  1. Asus X200MA Motherboard Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Motherboard Replacement: passo 2, imagem 1 %32
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Motherboard Replacement: passo 3, imagem 1 %32
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Motherboard Replacement, Battery: passo 4, imagem 1 %32
  5. Asus X200MA Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Motherboard Replacement: passo 6, imagem 1 %32
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Motherboard Replacement: passo 8, imagem 1 %32
    • Slide the battery up and out.
  9. Asus X200MA Motherboard Replacement, Fan: passo 9, imagem 1 %32
    • Remove the Two 4 mm screws using Phillips #0 phillips screwdriver.
  10. Asus X200MA Motherboard Replacement: passo 10, imagem 1 %32 Asus X200MA Motherboard Replacement: passo 10, imagem 2 %32
    • Unplug the set of wires located at bottom corner on fan.
  11. Asus X200MA Motherboard Replacement: passo 11, imagem 1 %32 Asus X200MA Motherboard Replacement: passo 11, imagem 2 %32
    • Lift up and out to completely the remove fan component.
  12. Asus X200MA Motherboard Replacement, Motherboard: passo 12, imagem 1 %32
    • Use Phillips #0 screwdriver to remove the eight 4.0 mm screws.
  13. Asus X200MA Motherboard Replacement: passo 13, imagem 1 %32 Asus X200MA Motherboard Replacement: passo 13, imagem 2 %32
    • Pull back the blue ribbon, freeing it from the latch.
  14. Asus X200MA Motherboard Replacement: passo 14, imagem 1 %32 Asus X200MA Motherboard Replacement: passo 14, imagem 2 %32 Asus X200MA Motherboard Replacement: passo 14, imagem 3 %32
    • Lift and pull the motherboard out from the hard drive and remove it from the base plate.
Conclusão
Alli Krininger
Membro desde: 11/11/19
391 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S2-G4, Stella Fall 2019 Membro de IUPUI, Team S2-G4, Stella Fall 2019
IUPUI-STELLA-F19S2G4
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 16
Duração total: 1,252
