Ir para o conteúdo principal
Asus X200MA Hard Drive Replacement
O que você precisa
  1. Asus X200MA Hard Drive Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Hard Drive Replacement: passo 2, imagem 1 %32
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Hard Drive Replacement: passo 3, imagem 1 %32
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Remove the black foam and adhesive located on top of the hard drive.
  5. Asus X200MA Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the following four screws:
    • Four 4 mm Phillips #0 using a phillips screwdriver.
  6. Asus X200MA Hard Drive Replacement: passo 6, imagem 1 %32
    • Slide out the hard drive
Conclusão
3 outras pessoas executaram este guia.
Vanessa Garcia
Membro desde: 01/22/15
1.763 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 21-24, Maness Winter 2015 Membro de Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
Membros da 4
Autoria de 8 guias
2 comentários
You FORGOT TO MENTION that one must remove the 2 Rubber feet to get at 2 more screws :-(((((((
Matthew Miller - Responder
Very poor!!! If you follow this instruction, you will destroy your Laptop. I did nearly destroying it. You did not show the 2 screws under the rubbers.
Minus 1000 points!!!
luft_ha - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 23
Duração total: 9,344
