Ir para o conteúdo principal
Asus X200MA Battery Replacement
O que você precisa
  1. Asus X200MA Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Battery Replacement: passo 2, imagem 1 %32
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Battery Replacement: passo 3, imagem 1 %32
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Battery Replacement, Battery: passo 4, imagem 1 %32
  5. Asus X200MA Battery Replacement: passo 5, imagem 1 %32
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Battery Replacement: passo 6, imagem 1 %32
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Battery Replacement: passo 7, imagem 1 %32
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Battery Replacement: passo 8, imagem 1 %32
    • Slide the battery up and out.
Conclusão
29 outras pessoas executaram este guia.
Vanessa Garcia
Membro desde: 01/22/15
1.763 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 21-24, Maness Winter 2015 Membro de Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
Membros da 4
Autoria de 8 guias
8 comentários
Thanks for the write up! Easy to follow, Great photos, and worked great!
nathaniel forward - Responder
Your step by step instructions were so easy to follow. Great job. Thanks! :)
Fernando H - Responder
I would like to buy a battery to it, Please suggest me the best portal site
jagadeeshkumar maddala - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 18
Últimos 30 dias: 54
Duração total: 35,508
