Ir para o conteúdo principal
Asus X200CA-HCL 1104G Motherboard Replacement
O que você precisa
  1. Asus X200CA-HCL 1104G Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Asus X200CA-HCL 1104G Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • Pry open the Keyboard/Touch pad.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  2. Asus X200CA-HCL 1104G Motherboard Replacement: passo 2, imagem 1 %32
    • Detach keyboard and touch screen cables
    • These are the cable that are holding the keyboard and touch screen together
  3. Asus X200CA-HCL 1104G Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the following four screws: Four 4 mm Phillips #0 using a phillips screwdriver.
    • Slide out the hard drive
  4. Asus X200CA-HCL 1104G Motherboard Replacement: passo 5, imagem 1 %32
    • Detach speaker
  5. Asus X200CA-HCL 1104G Motherboard Replacement: passo 6, imagem 1 %32
    • Remove motherboard screws
    • These would be located on the green panel which is the motherboard
    • Carefully remove motherboard
Conclusão
Svetlana Pimentel
Membro desde: 10/17/17
201 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 Membro de UMass Dartmouth, Team S1-G2, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 410
