Ir para o conteúdo principal
Asus X200CA-HCL 1104G Headphone Jack Replacement
O que você precisa
  1. Asus X200CA-HCL 1104G Headphone Jack Replacement, Headphone Jack: passo 1, imagem 1 %32
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • The parts you see underneath that panel are called the laptop's "internals".
  2. Asus X200CA-HCL 1104G Headphone Jack Replacement: passo 2, imagem 1 %32
    • Now, locate the audio board. This model has an L-shaped board. It can be found in the far left region of the internals.
  3. Asus X200CA-HCL 1104G Headphone Jack Replacement: passo 3, imagem 1 %32
    • Firstly, disconnect the two tiny wires that connect the audio board to other components. They can be found on a black square near the green decoder strip. Remember to be gentle with these delicate components.
  4. Asus X200CA-HCL 1104G Headphone Jack Replacement: passo 4, imagem 1 %32 Asus X200CA-HCL 1104G Headphone Jack Replacement: passo 4, imagem 2 %32
    • Using the Phillips 1 screwdriver, remove the six screws that hold the audio board in place.
    • Hint: the sixth screw may not be readily visible. It can be found in the bottom left corner of the audio board, under a small black flap.
    • With the screws removed, the audio board can be easily lifted out.
Conclusão
Samantha Wahl
Membro desde: 10/17/17
301 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 Membro de UMass Dartmouth, Team S1-G2, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 115
