Ir para o conteúdo principal
Asus X200CA-HCL 1104G Fan Replacement
O que você precisa
  1. Asus X200CA-HCL 1104G Fan Replacement, Fan: passo 1, imagem 1 %32
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • The parts you see underneath that panel are called the laptop's "internals".
  2. Asus X200CA-HCL 1104G Fan Replacement: passo 2, imagem 1 %32
    • The fan will be visible toward the bottom of the internals. It is semicircular with a small wire connected to the top of it.
    • Visually inspect the fan for any debris or blockage. If there is none, the fan probably needs to be replaced. To do that, we need to first disconnect the fan from the computer.
  3. Asus X200CA-HCL 1104G Fan Replacement: passo 3, imagem 1 %32
    • Disconnect the fan by gently pulling the connectors on the wire apart from each other.
  4. Asus X200CA-HCL 1104G Fan Replacement: passo 4, imagem 1 %32
    • Now, use the Phillips 1 screwdriver to unfasten the two screws holding the fan in place.
    • From here, the fan will lift easily out of the laptop.
Conclusão
Samantha Wahl
Membro desde: 10/17/17
301 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 Membro de UMass Dartmouth, Team S1-G2, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 261
