Ir para o conteúdo principal
Asus X200CA-HCL 1104G Battery Replacement
O que você precisa
  1. Asus X200CA-HCL 1104G Battery Replacement, Battery: passo 1, imagem 1 %32
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • The parts you see underneath that panel are called the laptop's "internals".
  2. Asus X200CA-HCL 1104G Battery Replacement: passo 2, imagem 1 %32
    • The battery will be easily visible towards to top of the internals. It is a long, black rectangle marked "Li-ion". Notice that the battery is currently secured by three screws. We will need to unscrew them in order to remove the battery.
  3. Asus X200CA-HCL 1104G Battery Replacement: passo 3, imagem 1 %32
    • You will notice that there are two gold screws and one silver screw holding the battery in place. Using the Phillips 1 screwdriver, remove the silver screw.
    • For the gold screws, pliers may be necessary. Be careful not to cut yourself on them; they can be finicky.
    • From here, the battery will lift easily out of the laptop.
Conclusão
Samantha Wahl
Membro desde: 10/17/17
301 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 Membro de UMass Dartmouth, Team S1-G2, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 414
