Ir para o conteúdo principal
Asus X200CA Keyboard Replacement
O que você precisa
  1. Asus X200CA Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Asus X200CA Keyboard Replacement, Keyboard: passo 1, imagem 2 %32
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Keyboard Replacement: passo 2, imagem 1 %32
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Keyboard Replacement: passo 3, imagem 1 %32
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
Conclusão
5 outras pessoas executaram este guia.
Jacqueline Collier
Membro desde: 10/09/17
1.047 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G2, Leahy Fall 2017 Membro de USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,041
