Ir para o conteúdo principal
Asus X200CA Display Replacement
O que você precisa
  1. Asus X200CA Display Replacement, Display: passo 1, imagem 1 %32
    • Wedge a metal spudger between the bezel and display cover.
    • Slide the metal spudger back and forth along the top, left, and right sides to pry apart the screen from the outer shell.
  2. Asus X200CA Display Replacement: passo 2, imagem 1 %32 Asus X200CA Display Replacement: passo 2, imagem 2 %32
    • Remove the six silver 2.7 mm screws securing the screen bracket to the screen bezel.
  3. Asus X200CA Display Replacement: passo 3, imagem 1 %32 Asus X200CA Display Replacement: passo 3, imagem 2 %32
    • Slice the silver foil tape with a spudger by applying pressure between the frame and the back of the screen case.
  4. Asus X200CA Display Replacement: passo 4, imagem 1 %32
    • Pull apart the black fabric tape with your fingers.
  5. Asus X200CA Display Replacement: passo 5, imagem 1 %32 Asus X200CA Display Replacement: passo 5, imagem 2 %32
    • Use an opening tool to peel off the sticker label securing the LCD cable to the LCD display.
    • Gently pull the sticker to disconnect the LCD cable.
    • Potential for device damage: Do not use excessive force while removing the video cable attached to the back of the LCD.
  6. Asus X200CA Display Replacement: passo 6, imagem 1 %32
    • Lift the LCD screen to remove it from the device.
  7. Asus X200CA Display Replacement: passo 7, imagem 1 %32 Asus X200CA Display Replacement: passo 7, imagem 2 %32 Asus X200CA Display Replacement: passo 7, imagem 3 %32
    • Remove the four silver 2.7 mm screws to separate the LCD screen from the two screen brackets.
Conclusão
3 outras pessoas executaram este guia.
Jacqueline Collier
Membro desde: 10/09/17
1.047 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G2, Leahy Fall 2017 Membro de USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 1,804
