Ir para o conteúdo principal
Asus W2W-A1 Keyboard Replacement
O que você precisa
  1. Asus W2W-A1 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Asus W2W-A1 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 Asus W2W-A1 Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
    • Unscrew the 2 4 mm Phillips head screws by the battery.
  2. Asus W2W-A1 Keyboard Replacement: passo 2, imagem 1 %32
    • Remove the panel above the keyboard with a plastic spudger.
  3. Asus W2W-A1 Keyboard Replacement: passo 3, imagem 1 %32
    • Once the panel is removed, use the spudger to pry out the keyboard.
    • Do not fully remove, for the keyboard is still attached to the ribbon cable.
  4. Asus W2W-A1 Keyboard Replacement: passo 4, imagem 1 %32 Asus W2W-A1 Keyboard Replacement: passo 4, imagem 2 %32
    • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
    • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Now you can fully remove the keyboard from the laptop.
Conclusão
Joe Redfearn
Membro desde: 04/14/14
97 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 13-29, Maness Spring 2014 Membro de Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 258
