Ir para o conteúdo principal
Asus Vivobook S500CA Touch Pad Replacement
O que você precisa
  1. Asus Vivobook S500CA Touch Pad Replacement, Touch Pad: passo 1, imagem 1 %32
    • Turn the device over so the back plate is facing up.
  2. Asus Vivobook S500CA Touch Pad Replacement: passo 2, imagem 1 %32
    • Use a Philips Head PH1 screwdriver to remove 10 screws (3 10mm screws and 7 5mm screws) around the perimeter of the back plate.
  3. Asus Vivobook S500CA Touch Pad Replacement: passo 3, imagem 1 %32
    • Remove the back plate by lifting it straight up.
  4. Asus Vivobook S500CA Touch Pad Replacement: passo 4, imagem 1 %32
    • Remove 9 5mm screws around the edge of the battery
  5. Asus Vivobook S500CA Touch Pad Replacement: passo 5, imagem 1 %32
    • Lift up the battery to reveal the battery terminal.
  6. Asus Vivobook S500CA Touch Pad Replacement: passo 6, imagem 1 %32
    • Unclip the battery terminal by prying straight up on the sides of the connector to release the clips.
  7. Asus Vivobook S500CA Touch Pad Replacement: passo 7, imagem 1 %32
    • Remove the silver tape at the edge of the touch pad.
  8. Asus Vivobook S500CA Touch Pad Replacement: passo 8, imagem 1 %32
    • Disconnect the white ribbon labeled “TP” by pulling gently.
  9. Asus Vivobook S500CA Touch Pad Replacement: passo 9, imagem 1 %32
    • Remove 2 5mm screws from the hard drive casing.
  10. Asus Vivobook S500CA Touch Pad Replacement: passo 10, imagem 1 %32
    • Slide the touch pad out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 648
