Ir para o conteúdo principal
Asus Vivobook S500CA Fan Replacement
O que você precisa
  1. Asus Vivobook S500CA Fan Replacement, Cooling Fan: passo 1, imagem 1 %32
    • Turn the device over so the back plate is facing up.
  2. Asus Vivobook S500CA Fan Replacement: passo 2, imagem 1 %32
    • Use a Phillips Head PH1 screwdriver to remove 10 screws around the perimeter of the back plate.
    • It may be helpful to lay out the screws in the orientation in which they are taken out, in order to help remember where they go.
  3. Asus Vivobook S500CA Fan Replacement: passo 3, imagem 1 %32
    • Remove the back plate by lifting it straight up.
  4. Asus Vivobook S500CA Fan Replacement: passo 4, imagem 1 %32 Asus Vivobook S500CA Fan Replacement: passo 4, imagem 2 %32
    • Remove 2 (.5 cm) Phillips Head screws found around the fan and 4 (.3 cm) Phillips Head screws found around the heat sink connector.
  5. Asus Vivobook S500CA Fan Replacement: passo 5, imagem 1 %32
    • Unhook the electronic connection located above the fan by pulling the white connector straight out of the brown socket.
    • This photo is for demonstration purposes only. Do not remove by pulling the wires. Instead, remove by pulling on the edges of the white socket.
  6. Asus Vivobook S500CA Fan Replacement: passo 6, imagem 1 %32
    • Remove the fan and connected heat sink by lifting straight out of the assembly.
  7. Asus Vivobook S500CA Fan Replacement: passo 7, imagem 1 %32
    • Replace fan and follow steps 1-5 in reverse order to complete repair.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 25
Duração total: 1,835
