Ir para o conteúdo principal
Asus Vivobook Q302LA-BHI3T09 Battery Replacement
O que você precisa
  1. Asus Vivobook Q302LA-BHI3T09 Battery Replacement, Battery: passo 1, imagem 1 %32 Asus Vivobook Q302LA-BHI3T09 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Before doing a replacement, make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place.
  2. Asus Vivobook Q302LA-BHI3T09 Battery Replacement: passo 2, imagem 1 %32 Asus Vivobook Q302LA-BHI3T09 Battery Replacement: passo 2, imagem 2 %32
    • Pry open the back casing using the opening tool along the side crevice.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus Vivobook Q302LA-BHI3T09 Battery Replacement: passo 3, imagem 1 %32 Asus Vivobook Q302LA-BHI3T09 Battery Replacement: passo 3, imagem 2 %32
    • Using the JIS #0 Screwdriver, remove the five 5.0 mm screws that hold down the battery.
  4. Asus Vivobook Q302LA-BHI3T09 Battery Replacement: passo 4, imagem 1 %32 Asus Vivobook Q302LA-BHI3T09 Battery Replacement: passo 4, imagem 2 %32
    • Disconnect the cable connected to the motherboard.
    • To remove, lift the ends using the opening tool.
Conclusão
Equipe
USF Tampa, Team S5-G5, Eyestone Spring 2018 Membro de USF Tampa, Team S5-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S5G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 530
